Date/Time: Sun, 08 Sep 2024 00:21:54 +0000
Footprint chart error
View Count: 99
[2024-07-01 19:31:35] |
Serajeddean - Posts: 2 |
Hello, I hope this email finds you in good health. I have an error with the delta difference on my chart if you can see the volume delta data it does not add up If you check the candle before the live market, you see: 1 0 = -31 3 2 = -61 9 4 = -6 4 1 = -43 I believe it is wrong correct? Kind regards, Seraj. |
[2024-07-01 19:33:21] |
We are not sure exactly what you are displaying in the two columns, but make sure that the bar spacing is wide enough that you are seeing the complete numbers. That is, we wonder if you are not seeing the full numbers because of the bar spacing.
