Date/Time: Wed, 27 Nov 2024 10:43:49 +0000
how to uninstall sierra chart
View Count: 2935
[2014-08-25 12:16:33]
User69517 - Posts: 1
I want to uninstall your trial version off my computer. I tried to uninstall it, but It does not show up in my programs. How do I uninstall it !!?? It never did work correctly anyway.
[2014-08-25 17:21:49]
Sierra Chart does work correctly. Either there was user error or you had a trouble with an external Data or Trading service.
A problem with an external Data and Trading services or an incorrect set up within Sierra Chart to use one of those services is the most likely issue.
Uninstall instructions can be found here:
https://www.sierrachart.com/index.php?page=doc/download.php#Uninstalling
