Date/Time: Sun, 24 Nov 2024 02:36:32 +0000
[Programming Help] - DRAWSTYLE_TRANSPARENT_TEXT_WITH_ALIGNMENT - TA_LEFT
View Count: 154
[2024-07-01 14:46:36]
User462086 - Posts: 196
From the documentation: "Text alignment can be optionally controlled through the sc.Subgraph[].Arrays[0][] array. Can be one of: TA_LEFT..."
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle
After trying "sc.Subgraph[sg].Arrays[0][sc.ArraySize-1] = TA_LEFT", and even setting all bar indexes to TA_LEFT, the text still plots center aligned.
How is this done?
[2024-07-01 16:13:46]
Sierra_Chart Engineering - Posts: 17154
Make sure you are running the latest Sierra Chart version.
[2024-07-02 07:46:17]
After specifying a vertical alignment as well, it now works as expected (v2652):
sc.Subgraph[sg].Arrays[0][sc.ArraySize-1] = TA_LEFT|TA_BOTTOM;
