Date/Time: Sun, 08 Sep 2024 00:14:30 +0000
Strange Footprintchart
View Count: 115
[2024-07-01 13:51:23] |
User131975 - Posts: 57 |
Hello, I have a footprint chart in MNQ, MES and MCL CHart and the ticks are set correctly. But in MES, the footprint chart somehow looks completely broken. But the templates are the same everywhere. Is this a bug? |
[2024-07-01 14:08:29] |
Hello, that was apparently a bug. I removed the study and loaded it again and then everything looked right. |
[2024-07-01 16:08:21] |
It is not a bug, it was a scaling issue.
[2024-07-01 16:13:56] |
Okay thank you I managed to fix it. |
