Date/Time: Wed, 23 Sep 2026 12:10:42 +0000
[Programming Help] - Acsil: Limit order to exit a long position, how ?
View Count: 748
[2024-07-01 12:57:19]
BenjFlame - Posts: 353
a position is entered with such code:
s_SCNewOrder NewOrder;
NewOrder.OrderQuantity = sc.TradeWindowOrderQuantity;
NewOrder.OrderType = SCT_ORDERTYPE_MARKET;
NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
NewOrder.Target1Offset = sc.TickSize * Input_DefaultTargetTickDistance.GetInt();
NewOrder.Stop1Offset = sc.TickSize * Input_DefaultStopTickDistance.GetInt();
int Result = sc.BuyEntry(NewOrder);
How to create new code to place limit order to exit that position at entryprice + 3 ticks ?
Attempt with such code:
NewOrder.OrderQuantity = Quantity; // This is defined elsewhere
NewOrder.OrderType = SCT_ORDERTYPE_LIMIT;
NewOrder.Price1 = entryPrice + sc.TickSize * 3;
int Result = sc.BuyExit(NewOrder);
fail
[2024-07-01 13:09:04]
Answer: the problem was because there was already an exit order placed on entry.
Solution is first cancel that order, then the limit with that code will pass.
