Date/Time: Sun, 08 Sep 2024 00:44:38 +0000
[Programming Help] - New Candlestick sound bar Alert.
View Count: 128
[2024-07-01 12:22:19] |
User669552 - Posts: 15 |
Good day. I used range tick charts. Kindly assist if you have a study that gives a sound alert when ever a new bar is created. If you don't have kindly help me to translate the below new bar alert conditions into a language that sierra understand. I would greatly appreciate if can give me a better solution. |
[2024-07-01 15:56:30] |
To have a sound alert for every new bar in a chart, enter the following for the Alert Condition on the "Chart >> Chart Settings >> Alert": =1 Then set the option for "Alert on Bar Closed" to "Yes". Make sure other options like "Enabled" and "Alert Number" are set for what you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-03 07:51:48] |
it's only giving me a sound after I have pressed okay. Kindly send me a screen showing how you entered "=1" on the alert and also other field. Remember I would like to hear a sound alert as soon as the candle close- on every closing candle. I use 8 range tick charts. A illustrative screen short would be helpful |
[2024-07-03 14:03:33] |
Attached is an image showing the settings. The one item that we forgot to mention is that you need to have "Reset Alert Condition on New Bar" set to "Yes".
