Date/Time: Wed, 27 Nov 2024 10:47:14 +0000
2 unrelated questions
View Count: 1420
[2014-08-25 12:10:51]
Herb - Posts: 9
1. In ACSIL, I would like to force a chart to be a reversal bar chart. Setting sc.ReversalTicksPerBar does not seem to work as documented. I seems to work only if the chart is a time based chart (and not e.g. a range bar chart).
2. In the settings for Interactive Brokers, I miss the option 'delay between histrical data requests' (version 1174), coming from version 1107. This option was very helpful for setting a longer delay in order to avoid pacing violations.
Thanks.
[2014-08-25 17:22:29]
1. We will look into this.
2. We will have to see about this. This whole problem with pacing violations is a complete nightmare and IB needs to resolve this. It really is absurd that this continues to this day.
[2014-08-27 05:12:37]
1. We think we know why this is happening and it will be resolved in the next release.
[2014-08-27 08:43:32]
1. Actually we now know why this happens. It is first necessary to set sc.RangeBarValue to 0 before setting sc.ReversalTicksPerBar , in order to change the Bar Period Type.
Unless the Bar Period Type is based upon seconds, you need to set the corresponding variable for the current Bar Period Type to 0 before changing to another one.
Date Time Of Last Edit: 2014-08-27 08:44:01
[2014-08-27 13:13:07]
Herb - Posts: 9
I already experimented with these settings, but I didn't get the correct reversal bars, and in the chart header and the chart properties it still says range bar.
[2014-08-30 17:28:58]
Herb - Posts: 9
I still await a satisfactory answer to both questions
Date Time Of Last Edit: 2014-08-30 17:31:11
[2014-08-30 20:27:40]
1. We have identified no problem with this. Here is a code example to work from:
SCSFExport scsf_ChangeBarPeriodTypeExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    sc.GraphName = "Change Bar Period Type Example";
    sc.StudyDescription = "This study is an example to change between Range and Volume Bars. It continuously changes between these two Bar Period Types, so the chart will continuously reload.";
    //During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance.
    sc.FreeDLL = 0;
    return;
  if (sc.LastCallToFunction == 1)
    sc.SecondsPerBar = 1*SECONDS_PER_MINUTE; // Set back to 1 minute
    sc.RangeBarType= IBPT_RANGE_IN_TICKS_STANDARD;
    sc.RangeBarValue = 0;
    sc.VolumePerBar = 0;
    sc.NumberOfTradesPerBar = 0;
    sc.DeltaVolumePerBar = 0;
    sc.ReversalTicksPerBar = 0;
    sc.RenkoTicksPerBar = 0;
    return;
  if (!sc.AreRangeBars())
    sc.RangeBarValue = 2;
  else if (!sc.AreVolumeBars())
    sc.VolumePerBar = 5000;
2. The proper solution to this will be to change to package 3 to use the Sierra Chart Historical Data service which is now integrated with the Interactive Brokers trading service. This will be used for both Historical Daily and Historical Intraday data downloads.
Let us know if you would like us to do that.
What exchanges are the symbols you are charting from?
Date Time Of Last Edit: 2014-08-30 20:29:24
[2014-08-31 13:20:33]
Herb - Posts: 9
Thank you for your answers.
1. I see. The trick is to go back to a time based chart in a first step. Perfect, that works.
2.Reintroducing the option ‘delay for historical data requests’ would be a far more customer friendly solution and should not be too difficult to do. Please consider.
[2014-08-31 19:39:54]
1. You most definitely do not have to go back to time-based bars. Where does the code show this? You do not have to do this.
The code example continuously switches between range and volume bars. It does not go back to fixed time bars.
2. How is it more customer friendly? Using the Sierra Chart Historical Data Service if it provides data for the markets that you require, is monumentally more customer friendly. It just works without any trouble. There is no guessing and effort to determine the appropriate time delay. It provides high-quality data with bid volume and ask volume and should be probably about 100 times faster in some cases.
Date Time Of Last Edit: 2014-08-31 19:40:33
