Date/Time: Sun, 08 Sep 2024 00:08:10 +0000
Crosshair moves all my charts
View Count: 102
[2024-07-01 08:22:30] |
User752860 - Posts: 3 |
Hi, this has never happened before but now when I click crosshair and hover let's say over my yearly charts,all of my charts start moving to that date like weekly,monthly,daily etc and its very annoying as it gets laggy and I have to individually scroll back to today's date. Does anyone know how to disable that crosshair would stop following to that date when all I want to do is just check the prices thats why i have it enabled. Hope this makes sense,thanks
[2024-07-01 15:43:51] |
Make sure that "Tools >> Synchronize" is set enabled. Refer to the following: Chart Drawing Tools: Synchronize Charts (Tools >> Synchronize Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-01 15:58:56] |
Perfect,it solved my problem, I wanted to actually for it not to be synchronized so I now turned it off,thank you for your help.
