Date/Time: Sun, 08 Sep 2024 00:08:27 +0000
Symbol not found, update from server doesn't help
View Count: 117
[2024-07-01 07:29:29] |
User745789 - Posts: 252 |
Hello, I have a Denali Eurex subscription. Today I also started a CQG subscription for SGX I am able to connect to my CQG data feed with my login details from within SC. But I am not able to open a chart, as the symbol is not found (image). I try Symbol Settings > Update from Server, but it doesn't help. How do I use the correct symbol? I will send my message log. UPDATE: it appears I am indeed able to open charts for all symbols from SGX. Except the Nifty 50 index, per the second image. This is a "special" symbol at SGX as it is actually traded on the NSE but also available on SGX via something called GIFT. If I check the CQG website to lookup the SGX symbol for Nifty 50, it does not exist. It seems I am using the correct symbol. But CQG is rejecting it. I doubt this is a SC issue. Date Time Of Last Edit: 2024-07-01 08:02:40
[2024-07-01 11:45:05] |
Sierra_Chart Engineering - Posts: 16292 |
Contact CQG for the correct symbols to use.
