Date/Time: Sun, 08 Sep 2024 00:14:15 +0000
Chart Values Tool Shows Crosshair but no values
View Count: 122
[2024-07-01 02:41:36] |
BruceWilson - Posts: 15 |
I have just updated to version 2652 in the hope that it would remedy the problem that came about when I last updated (2646 if I recall correctly). At the previous update the chart values tool ceased working. Clicking on the tool will bring up the crosshairs but no data window is displayed. I could not find any topic addressing this in the support board. Are you able to advise please? Thank you BW |
[2024-07-01 02:52:17] |
Sierra_Chart Engineering - Posts: 16292 |
Regarding this, refer to: Chart Drawing Tools: Cannot See Values Windows? This is not a version specific issue. There is a procedure to resolve. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
