Date/Time: Sun, 08 Sep 2024 00:18:03 +0000
Sierra Chart and Trading View Data is not matching
View Count: 230
[2024-06-30 19:52:46] |
User267494 - Posts: 3 |
My sierra chart and trading view charts don't match on any timeframes. I have the exact same settings on both programs that my collogues have however theirs's all match. I've tried deleting and re-downloading both programs. Any suggestions would be greatly appreciated. Thanks.
[2024-07-01 04:34:44] |
Sierra_Chart Engineering - Posts: 16292 |
What is the timeframe of the chart bars? Are they fixed time frame bars?
[2024-07-01 16:57:32] |
I use the 1hr, 4hr and daily time frames. I'm not using fixed time frame bars just regular.
[2024-07-02 20:17:07] |
Therefore, in this case the reason for differences with chart bars would be because of the bar starting times. Refer to: Chart Session Times: Bar Starting Times Also tell us the symbol of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-02 23:48:11] |
Thank you and yes I've already set the bar times, session times and time zone to the same as my collogues and theirs match trading view and mine don't. I'm trading forex so all the FXCM pairs.
