Date/Time: Sun, 08 Sep 2024 00:02:51 +0000
Volume profile changes on timeframes larger than 4-hour candles
View Count: 110
[2024-06-30 14:17:11] |
User183193 - Posts: 4 |
Hello, when I set the 4-hour candles to daily and weekly, the volume profile turns dark blue. Please review the screenshots. How can I solve this problem?
![]() Attachment Deleted. |
[2024-07-01 15:20:51] |
Daily data does not contain Bid/Ask information. If you want to view the Bid/Ask for a Daily and higher timeframe, then you have to build those bars using the Intraday data, which means setting "Chart >> Chart Settings >> Data Limiting >> Chart Data Type" to "Intraday Chart Only". Refer to the following: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
