Date/Time: Sun, 08 Sep 2024 00:00:50 +0000
Max Loss Feature?
View Count: 116
[2024-06-30 02:42:57] |
User597568 - Posts: 3 |
Hello, does Sierra Chart have a feature that will block you from placing trades for the day, once you hit your desired max loss? A feature that CAN'T be turned off/on during normal trading hours. Rithmic has the feature BUT you can turn it off/on any time you want which defeats the purpose. Thanks. |
[2024-07-01 14:56:54] |
The Teton Order Routing service has this ability, but right now the only broker that has it implemented is Stage 5. If you are using Stage 5, then refer to the following for how to set this up: https://www.sierrachart.com/index.php?page=doc/VideoLibrary.php&Video=Server_Side_User_PL_Management This option is also available with our "Simulated Futures Trading Service", which is what is being referenced in the video. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
