Date/Time: Sun, 08 Sep 2024 00:33:14 +0000
[User Discussion] - TPO Chart
View Count: 177
[2024-06-29 19:22:32] |
User131975 - Posts: 57 |
Hello, unfortunately I have searched Google for a long time but have not found an answer. How do I set the "Letter/Block Price Increments in Ticks" correctly in the TPO chart? is there a formula or something? |
[2024-06-29 20:52:19] |
Sierra_Chart Engineering - Posts: 16292 |
What is the symbol of the chart? And are the profiles, a period of one day? Or what is the Time length? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-29 20:52:43
[2024-06-29 21:03:14] |
First of all, thank you very much for your answer. I want to use the TPO chart in MNQ, MES and MCL.
[2024-06-29 21:04:11] |
And I use the TPO chart for the RTH and ETH session separately (daily) in the 30 min timeframes
[2024-07-01 14:53:15] |
There is no magic formula. You need to adjust the "Letter/Block Price Increment in Ticks" for what works best for you for each chart. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-03 19:44:02] |
Thank you but would it be possible that you can give me an setting for the NMQ? I just want to be sure if I do it right
[2024-07-03 20:07:10] |
We can not tell you this. It is a personal choice on how you want to view the data. It is a tradeoff of being able to view the letters/blocks against the tick size of the chart. It really depends on what you need to see from your TPO chart.
[2024-07-03 20:11:17] |
I like to follow Jim Dalton and use his way of trading. But if I make it so that I can see the letters clearly and compare the TPO chart with a 30 minute candlestick chart then I see that a letter is a few ticks higher than the high of the candle. And that's what confuses me so much.
[2024-07-03 21:25:13] |
I also want to recognize tails but I have the feeling that if I set it to auto (0) there will be tails everywhere.
