Date/Time: Fri, 25 Sep 2026 11:21:33 +0000
Extend ETH TPO TPOC
View Count: 1164
[2024-06-29 18:00:37]
anthonyvegas - Posts: 30
I have a fairly common TPO/Volume by Price chart setup showing ETH and RTH sessions. I would like to grab ONLY the most recent ETH session TPO POC ( not volume POC ) and copy this value/line onto my candlestick chart as a key line to trade around. Have not been able to find a way to do this. See attached chart...
Thank you,
Anthony
imageUntitled-2024-04-23-1706.png / V - Attached On 2024-06-29 17:59:25 UTC - Size: 393.16 KB - 238 views
[2024-07-01 14:41:42]
John - SC Support - Posts: 48003
The only way to do this would be to have a separate chart setup to just show the ETH session (as the main session) and then add the "TPO Value Area Lines" study to that chart. This will then give you the most recent ETH Sessions POC. You can then use the Study/Price Overlay to overlay this to another chart. Refer to the following:
Chart Session Times
Study/Price Overlay Study
[2024-07-01 19:36:20]
Thanks for the quick reply. I was able to create an ETH TPO by setting the TPO to a start data/time and end date/time. This TPO does match with my other ETH TPO charts including the VAH/L and POC match. Then I added the TPO Value Area Lines study. I have tried many many settings for this study and I cannot get these new lines to line up correctly with those on the TPO. See screen shot for the disparity...
Thanks,
Anthony
image2024-07-01_123237.png / V - Attached On 2024-07-01 19:35:41 UTC - Size: 314.28 KB - 218 views
[2024-07-01 22:09:27]
We are not quite sure of the setup you are trying to do, but you can not use the TPO Value Area Lines with a TPO Chart. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
