Date/Time: Fri, 27 Nov 2026 04:37:41 +0000
replay chart DOM doesn't sync with replay price values
View Count: 806
| [2024-06-29 17:19:02] |
| User953115 - Posts: 6 |
https://www.sierrachart.com/image.php?Image=1719681178430.png Chart DOM has auto center to last price selected. This is the only chart open, also only chart saved. Previously I had the DOM updating price that was far away from what replay showwd. |
| [2024-06-30 15:12:03] |
| nicktrader - Posts: 817 |
It seems that the "Single Chart" mode is set for your replay. The DOM and chart are not synchronized. Either "All Charts..." or "... same Link..." |
| [2024-07-08 14:37:31] |
| Sierra_Chart Engineering - Posts: 25500 |
Refer to: Replaying Charts: Replaying Trade DOM Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
