Date/Time: Sat, 13 Jun 2026 08:04:54 +0000
volume by price
View Count: 467
| [2024-06-29 08:17:10] |
| User19991027 - Posts: 13 |
I use two computers to view the symbol QQQ using volume by price, why is it different? I didn't use any additional settings, one of them would have more spikes
Attachment Deleted. |
| [2024-06-29 09:11:00] |
| Sierra_Chart Engineering - Posts: 24012 |
We do not understand what the question is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-29 09:11:05
| [2024-06-30 07:47:00] |
The delicacy level of the volume by price indicator varies, compare the two graphs
| [2024-07-01 15:05:39] |
| John - SC Support - Posts: 46668 |
For one thing, you have the Volume by Price set to view "Visible Bars". As such, you need to ensure that the number of bars displayed in the charts is exactly the same. Also, you need to ensure that the settings for the Chart and for the Volume by Price study are the same. We think there may be a difference in the "Ticks per Volume Bar" for the study. But there could be any number of other things. You need to go through all of them to make sure they are exactly the same. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
