Date/Time: Sun, 08 Sep 2024 00:03:39 +0000
[User Discussion] - Downloading Issue
View Count: 102
[2024-06-29 07:49:34] |
User538264 - Posts: 26 |
I have been constantly facing this issue where in If I want to download 10 years of data for backtesting only half of the files gets downloaded rest and stuck there forever DL count never moves beyond a certain point. Should I limit my download or do something else, how should I do it?
[2024-06-29 07:57:59] |
Well no the problem persists even If I want to download 300 days data
[2024-06-29 10:39:13] |
Sierra_Chart Engineering - Posts: 16292 |
To solve this, follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance You may want to increase the Intraday Data Storage Time Unit to 10 seconds or higher. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-29 10:39:34
