Date/Time: Sun, 08 Sep 2024 05:04:05 +0000
New CBOE SPX feed
View Count: 300
[2024-06-28 22:43:20] |
User310898 - Posts: 38 |
I subscribed to the New CBOE Global Indexes for $6 p/m. All seems excellent however when I access the S&P500 Cash Index symbol SPX_CGI data looks perfect however only goes back to 27 May 2024 ie around a month. How can I get historical data going back further than 1 month? Am I making a mistake? I tried $INX and it goes back years but that is not real time. I would like my real time feed to have history please advise much appreciated. Thanks |
[2024-06-28 23:20:46] |
joshtrader - Posts: 484 |
See this post: New CBOE Global Indexes Now Available as of June 1, 2024 | Post: 384706
[2024-06-30 08:45:03] |
Hi @sierrachart I have seen this post New CBOE Global Indexes Now Available as of June 1, 2024 | Post: 384706 that said about 2 weeks. Do you have any update on the timing of this please. Thank you |
[2024-07-01 22:19:53] |
Sierra_Chart Engineering - Posts: 16292 |
This may still be several weeks away. Obtaining and adding historical data is more involved than wwe initially thought.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-01 22:19:58
[2024-07-08 13:42:02] |
Thanks @Sierra_Chart Engineering Can I get the feed from another source whilst I wait for you to update the historical data as it is nigh on impossible to use your feed with barely any history available? Thanks |
[2024-08-02 12:42:35] |
Since it's been a month since the last update, I'd like to ask please when the data backfill might be available. Likely quite a few of us are using the CBOE data and it's really great, but I desperately need the previous data.
[2024-08-02 12:50:44] |
Refer to: New CBOE Global Indexes Now Available as of June 1, 2024 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-02 16:20:20] |
User754716 - Posts: 11 |
I tried downloading the CBOE SPX USING Sp_CGI SP 500 but did not get anything. Any new download available?
[2024-08-02 17:06:47] |
The symbol for the SPX is "SPX_CGI". Make sure you have the symbol set correctly.
