Date/Time: Sun, 08 Sep 2024 00:02:37 +0000
Order fill audio alerts
View Count: 144
[2024-06-28 17:46:00] |
User585104 - Posts: 122 |
Hi, Audio alerts for orders fills has stopped working in v2651 Thanks |
[2024-06-28 18:36:29] |
We just tested this and are not seeing any issue for order fill alerts in version 2651. Refer to the following: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-28 19:10:41] |
Hi there, Yeah I checked everything before I message you guys. The alerts log is blank/empty. I set alerts on order fills when I switched to SC a year or 2 ago and it has worked fine ever since, until this update, possibly also v2650 but I only used v2650 for a few hours so I'm not sure. Global settings, alerts is all set up fine. All other alerts work fine, apart from TP fills or SL fills. Also I haven't changed any settings in SC, it just stopped working on the new update. Thanks Date Time Of Last Edit: 2024-06-28 19:13:23
[2024-06-28 20:13:56] |
We did not realize that this was for Targets and Stops. We are able to reproduce this and it will be looked into.
[2024-06-29 15:22:52] |
Sierra_Chart Engineering - Posts: 16292 |
This will be resolved in the next release.
