Date/Time: Sat, 26 Sep 2026 06:29:25 +0000
FORMULA TO REFERENCE PREVIOUS SWING HIGH/LOW POINTS.
View Count: 553
[2024-06-28 14:54:51]
User357489 - Posts: 72
Hi there, I currently have a zig zag study (custom, not SC), which is ID17.SG1 (SG1=PRICE OF LINE), SG3 =THE LABELS OF THE SWING/ ZIG ZAG VOLUME.
I'm looking to express something along the lines of =CROSSFROMBELOW(C[0] > PREVIOUS SWING HIGH)- my secondary condition in this example would be IF PREVIOUS SWING HIGH VOLUME >=100,
[2024-06-28 15:15:31]
John - SC Support - Posts: 48028
We do not have enough information to be able to answer this question, as we do not know anything about how the custom study has the information.
[2024-06-28 15:28:20]
Hi John
The only additional information I can give you from a user perspective is it's relative column info on the spreadsheet, say AA gives the volume values for each swing point the study outputs, it is either a value>0, value< or value=0. So a long move down prior to creating a new swing level, would see AA showing several rows of 0's until the new swing point created and AA3 for example, shows a number +/-
Hope that helps a little for what it's worth!
Thanks again
[2024-06-28 16:36:07]
What we can tell you is that you will need to modify the formulas at the following link to get what you need:
Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values
