Date/Time: Sun, 08 Sep 2024 00:44:19 +0000
Delayed data feed
View Count: 112
[2024-06-27 15:05:01] |
User840203 - Posts: 2 |
Hello , I am thinking about getting the base package 5 to backtest and study the chart at the end of the trading session (I understand that it will be 15min delayed for the eurex). My question is : will the volume profile and market profile be as accurate and precise as the denali live data feed? I am mostly looking at studying the volume profile and I need it to be as accurate as live trading , wondering if I will get the same volume profile as if I had the live denali feed? To make my question as precise as possible : Will the High/Low volume node be exactly at the same price on the delayed data feed and on the live denali data feed ? Thank you |
[2024-06-27 15:30:30] |
Yes, they will be exactly the same. It is the same data only delayed. Will the High/Low volume node be exactly at the same price on the delayed data feed and on the live denali data feed ?
For the exact same time period - yes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
