Date/Time: Sun, 08 Sep 2024 00:22:14 +0000
Frozen Chart
View Count: 103
[2024-06-27 14:15:23] |
User841161 - Posts: 209 |
Why would my 2 subinstances be frozen but my main instance is working ok?
[2024-06-27 14:43:19] |
Sierra_Chart Engineering - Posts: 16292 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-27 15:29:58] |
After I disconnected and reconnected seems to be working now?
[2024-06-27 15:43:24] |
Ok. Not sure why there was an issue.
