Date/Time: Sun, 08 Sep 2024 00:36:15 +0000
Session time
View Count: 150
[2024-06-27 06:58:48] |
Federico Roveda - Posts: 34 |
Hi there, if I set the 'main' session time equal to the US session for equities (cash session 9:30-16:00 ET) is there a way to merge Friday's evening session and Sunday's reopening together to not have different ETH profiles for basically the same ETH session? Screenshot attached. Thanks
[2024-06-27 13:43:51] |
There is not a way to automatically associate Friday Evening with Sunday Evening data. But with the TPO profiles, you can manually merge those two together so you will see them as a single profile. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Splitting and Merging TPO Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-27 13:46:36] |
Ok thanks, is there a similar workaround for the daily (candlestick) chart?
[2024-06-27 15:05:29] |
Tony - Posts: 502 |
Federico, was your original question referred to VbP? Are you having daily VbPs on your chart?
[2024-06-27 15:11:01] |
There is not an option to combine Friday with Sunday daily bars. There is the option for "Chart >> Chart Settings >> Bar Period >> Combine Sunday-Monday Daily Bars". Refer to the following: Chart Settings: Combine Sunday-Monday Daily Bars (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-27 15:13:09] |
No actually it’s a more general question about the session time in between weeks because we have the ETH that begins Friday after cash or pit session and Sunday reopen split despite it’s the same ETH session from the close of Friday to the open of Monday. So whatever you draw, being the candle chart, VbP, TPO is split as well.
