Date/Time: Sun, 08 Sep 2024 00:20:58 +0000
Micro NAT GAS
View Count: 136
[2024-06-27 02:09:47] |
User423634 - Posts: 22 |
Hello, I am using CQG and AMP Futures and am looking for the micro NAT Gas futures, it is not under the NYMEX tab. Can you help me please?
[2024-06-27 13:17:51] |
You just need to type in the appropriate symbol. For CQG the Micro Natural Gas Futures symbol is F.US.MNG?## where ? is the contract month character and ## is the 2 digit year.
[2024-06-30 16:13:00] |
Sierra_Chart Engineering - Posts: 16292 |
Post #2 will not work for CME and EUREX. You will not be able to receive market data.Those symbols we have to set up for CQG ourselves. We have not yet done Micro natural gas. CQG uses nonstandard mangled symbols. And it takes extra effort.
[2024-07-02 22:44:02] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
