Date/Time: Wed, 27 Nov 2024 10:38:27 +0000
not receiving data
View Count: 1007
[2014-08-24 23:57:38]
George - Posts: 60
I am not receiving any data using version 1174 and Rithmic. Also, not receiving SC Historical data using version 1178.
Please advise.
[2014-08-25 00:01:45]
User77348 - Posts: 3
I also am not receiving any data using v.1178 and Rithmic.
[2014-08-25 00:43:09]
We are noticing this as well. This is across all of our Data connections including our own CME direct connection.
Either the CME has a problem or is it a holiday?
In regards to not receiving data from the Sierra Chart Historical Data Service, do you mean after the most recent Friday close? You should be getting data from before that time.
Date Time Of Last Edit: 2014-08-25 00:43:50
[2014-08-25 00:53:59]
birdaa - Posts: 12
CMEGroup @CMEGroup
CME Globex is experiencing a technical issue and we’re working towards a solution. We’ll keep you posted on any updates.
