Date/Time: Fri, 11 Sep 2026 21:12:37 +0000
only showing what current price is
View Count: 498
| [2024-06-26 21:00:37] |
| User843922 - Posts: 1 |
Hi, how do i the price list down the right hand side? at the moment my chart only shows the current price therefore it is hard to know what previous prices are as it only shows current price? Any help would be appreciated.
| [2024-06-26 21:22:04] |
| John - SC Support - Posts: 47853 |
It sounds like your color settings for the text in the Values Scale is set to be the same as the background. Check the color settings of the following 2 graphics settings items to see if one of them fixes the problem. Make sure you are changing the appropriate Global or Chart specific graphics settings for that chart: - Chart Text - Chart DOM Values Scale Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
