Date/Time: Fri, 18 Oct 2024 04:45:09 +0000
hide some drawings but not all between charts
View Count: 151
[2024-06-26 17:07:20] |
SafSaf - Posts: 84 |
hi support, is there a way to select specific drawings on a chart to share with other charts within the linked charts without sharing the drawings you want to keep specific to that chart?
[2024-06-26 18:17:22] |
John - SC Support - Posts: 35333 |
Yes, but the way to do this is to set the individual drawings you do not want to copy over. You do this by right-clicking and selecting the option for "Allow Copy to Other Charts" to remove the checkmark for that drawing. Refer to the following: Copying Chart Drawings from Other Charts Automatically: Preventing Specific Chart Drawings from Being Copied You can set which way you want your drawings to be set up front with regards to this setting. Refer to the following: Chart Drawing Tools: Allow Copy to Other Charts for New Drawings (Global Settings >> Tool Settings >> General >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-26 18:51:24] |
worked a treat.... one more question on the same subject... i have an avwap setup which i can set anywhere on my chart,,, settings as per attached... is there a way that study can be copied over to t=other charts too so i don't have to go into each chart and set it manually?
Screenshot 2024-06-26 144842.png / V - Attached On 2024-06-26 18:49:22 UTC - Size: 63.78 KB - 29 views |
[2024-06-26 19:37:11] |
Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
