Date/Time: Sun, 08 Sep 2024 00:21:11 +0000
Server Side User Profit/Loss Management Settings Not Updating - (AMP)
View Count: 145
[2024-06-26 16:21:37] |
User100912 - Posts: 100 |
Following the video, entered some values in my AMP trading account. Clicked Commit This Tab - received message Commit was successful. Clicked Update - received message Update was successful But the values do not show under Read Only Values (expected behavior: read only values populate with the values I have just committed). v 2646, connected to a live AMP account, trading is enabled, simulation mode is off, I am able to place an order. |
[2024-06-26 16:49:46] |
Sierra_Chart Engineering - Posts: 16292 |
AMP does not support that functionality. Right now only Stage 5. We intend to have it supported with other brokers as soon as we can. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-26 17:10:33] |
Connected to my account at Advantage/Stage 5. This appears to work partially. The CalculatedLoss value populates but the the profit management field doesn't populate. Date Time Of Last Edit: 2024-06-26 17:19:40
[2024-06-28 17:15:11] |
It is definitely functioning properly. What are the exact names of the fields you are referring to.
