Date/Time: Sun, 08 Sep 2024 00:39:40 +0000
renko
View Count: 148
[2024-06-26 13:08:21] |
User220939 - Posts: 36 |
Bonjour, Je voulais vous signaler un problème sur les bougies renko. Quand la bougie cloture l'ouverture de décale. Sur le S&P je viens d'avoir un bougie baissière, elle a ouvert a 5524, et quand elle a cloturé l'ouverture s'est décalée a 5522.50 Cdlt |
[2024-06-27 17:50:11] |
Sierra_Chart Engineering - Posts: 16292 |
From Google Translate: Good morning,
I wanted to report a problem with the renko candles. When the candle closes the shift opening. On the S&P I just had a bearish candle, it opened at 5524, and when it closed the opening moved to 5522.50 Was the chart data reloaded? The open price should not be changing. Are you setting the Renko Chart bars through Chart >> Chart Settings >> Bar Period? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-27 17:50:12] |
I wanted to report a problem with the renko candles. When the candle closes the shift opening. On the S&P I just had a bearish candle, it opened at 5524, and when it closed the opening moved to 5522.50 Was the chart data reloaded through Chart >> Reload and Recalculate ? The open price should not be changing. Are you setting the Renko Chart bars through Chart >> Chart Settings >> Bar Period? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-27 17:50:29
