Date/Time: Sun, 08 Sep 2024 00:42:20 +0000
Cumulative ASK / BID lines
View Count: 113
[2024-06-26 12:28:36] |
User490082 - Posts: 3 |
So many options... Googled it but did not find it. Cumulative BID / ASK lines, like the CVD line but exclusively for bids and asks separetly. Not just total / bar or brick but cumulative. Where do I find this? Regards, Benjamin L |
[2024-06-26 15:54:18] |
There is not a study that does this directly, but you can create it using a couple of studies. To start with, you need a study that has the Bid and Ask volumes per bar. You can use either the "Numbers Bars Calculated Values" or the "Bid Volume vs Ask Volume" studies. Then you use the "Cumulative Sum of Study" and reference the particular subgraph from the above study you used. Refer to the following: Numbers Bars: Displaying Numeric Information Below Numbers Bars Bid Volume vs Ask Volume Cumulative Sum of Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
