Date/Time: Sun, 08 Sep 2024 00:34:30 +0000
[Programming Help] - Drawing text on the chart using DRAWING_STATIONARY_TEXT
View Count: 133
[2024-06-25 19:54:24] |
User504477 - Posts: 26 |
How do I draw a stationary text on top left and bottom right of the chart regions? TY!
[2024-06-26 02:29:51] |
User43 - Posts: 101 |
did you follow the instructions on how to work with sc.UseTool Using Drawing Tools From an Advanced Custom Study: Code Example Just to point out though that you can just use the stationary text tool from the tools menu. |
[2024-06-26 04:04:30] |
Yes, I did. Is there a way to specify x,y location on the chart or it would have to be bar high/low?
