Date/Time: Sun, 08 Sep 2024 00:38:09 +0000
Changing Default Tool Configuration Settings
View Count: 138
[2024-06-25 16:37:10] |
User624595 - Posts: 203 |
Have read the doc, tool configuration keeps resetting back to TC1 as default. How can we set it to select TC8 as default on tool selection?
[2024-06-25 18:06:34] |
There is not a "Default" configuration. Whatever is the last selected configuration used for a tool is what will be used the next time. If you want to use a specific configuration with a tool, then we recommend setting up a Control Bar button to select the tool and configuration together. Refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-25 19:45:46] |
It seems to reset to the TC1, and not retain the last used TC8. Can the configuration be saved in the tool selection in the right click menu?
[2024-06-25 21:18:10] |
Please give us the workflow that you are using (the exact order of steps and what you are selecting - starting with selecting a tool and configuration and ending when you see that the configuration is not set to TC8). Something is not quite correct given what you are stating.
