Date/Time: Wed, 30 Sep 2026 10:16:41 +0000
Consolidated Price Levels on the Chart DOM
View Count: 1692
| [2024-06-25 15:57:41] |
| MarkusK - Posts: 126 |
I use the setting "Chart Settings > Chart Data > Volume at Price Multiplier for Intraday Chart" to consolidate four price levels into one (the setting is set to 4). This works perfectly well with e.g. the numbers bars study, but it's not consolidating the price levels in the Chart DOM. Please see attached screenshots for illustration: It seems that the volume at price multiplier option is only applied to the chart studies but not to the chart DOM on the right (which makes the DOM completely unreadable because everything is crunched up). Could you please advise what to do? Is there any way to consolidate the price levels in the Chart DOM as well? Is there a separate setting for that? |
| [2024-06-25 18:00:41] |
| John - SC Support - Posts: 48062 |
Refer to the following settings: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-06-26 05:03:43] |
Works perfectly, thank you very much for the quick reply John!
