Date/Time: Sat, 12 Sep 2026 16:06:13 +0000
Black Background on chart
View Count: 819
| [2024-06-25 15:31:26] |
| MarketBeast - Posts: 48 |
Hello Team, How can I remove this black background behind market depth chart please see here https://prnt.sc/EzHM5DVj6RON I just want to see specific volume percentage and that black background is really annoying any idea on how to hide it? Thank You! A. |
| [2024-06-25 17:47:11] |
| John - SC Support - Posts: 47854 |
There is not a way to do what you are wanting. You have setup a Numbers Bars column to display a volume profile, and the coloring is set to black for the Range 1-3 Up/Down colors. Therefore, the profiles that fall into those categories are being drawn in black. This will make them appear non-existent when you do not have anything else behind them, so they blend into the background, but with the Market Depth Historical Graph, they are very visible. You can try and see if there is another coloring option that will work better for you in which those profiles will not be showing, but we do not think there is an option for what you are doing. The only other recommendation we have is to display numbers in that column and color the numbers for what you want. This might be a bit less intrusive. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-06-26 14:59:03] |
Hello John, Thanks for your recommendation. If I use text I think I will still see the black text correct? which will look less intrusive for sure but it would be nice to hide data we don't need or I might be asking for too much. Thank you though. |
