Date/Time: Sun, 08 Sep 2024 00:00:15 +0000
How do I change the color of the Trade Positions window?
View Count: 82
[2024-06-25 14:44:34] |
User429142 - Posts: 41 |
Can you direct me to the area in the graphical settings where I can change the color of the "position window" from white to something else. see SS.
[2024-06-25 17:34:14] |
This is a "General Text Window", so the graphics settings that start with "General Text Window" are the items to change. In particular the background is controlled by the "General Text Window Background Color". Note that you may need to close and re-open the Trade Positions window to see the color change after you have changed it in the graphics settings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
