Date/Time: Sun, 08 Sep 2024 00:10:17 +0000
Custom Study not showing in the list
View Count: 160
[2024-06-25 14:38:59] |
User550801 - Posts: 2 |
Hello, I have created a custom study and am trying to add it to my chart, but it's not showing up in the custom study list, although the file ("C:\SierraChart\Data\tutorial_02_64.dll") is in the appropriate directory. This is a study that I custom coded and compiled using the remote build function. This is the second study I've made, and the first one showed up just fine. I'm not sure what has changed. I have also restarted SC but no luck. I attach a screenshot of the code as well as the interface where you add the customer study. |
![]() ![]() Attachment Deleted. |
[2024-06-25 17:30:21] |
Please try renaming the file so there is only a single underscore character before the _64, so something like "Tutorial2_64.dll".
[2024-06-25 19:09:39] |
Thanks! That seemed to fix the issue. Wasn't obvious though.
