Date/Time: Sun, 08 Sep 2024 00:38:19 +0000
ZB Yields chart (F.US.Z30YM24) has not updated since 13 June 2024.
View Count: 160
[2024-06-25 13:53:11] |
UserCD - Posts: 11 |
I've tried rolling over but no data - so it appears to be a problem with the feed. Can this be addressed please?
[2024-06-25 16:58:58] |
The Z30Y symbol from CQG is not the ZB symbol traded on the CBOT. It is the "30Y", which is the Micro 30 Year Yield Futures. This is a low volume traded product. There is only Daily historical data available for it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-26 03:15:01] |
Thx John - however the data prior to 13 June 2024 was 1m or less. I had a 5m chart model using yields which I can no longer use unless I can get 5m or less data. I just checked again and there is no data for this symbol beyond 13 June 2024. Once again thanks for your response. Regards, Clive |
[2024-06-26 15:14:21] |
After June 13, 2024 there was 1 trade on June 24, 2024 for the M contract of the 30Y symbol. Attached is a chart image showing this. This also matches what you will see for this on the CME Group website.
