Date/Time: Tue, 15 Sep 2026 03:30:29 +0000
How do I manage my Daily Loss Limit - Unable to reduce from default 90% to lower values
View Count: 615
[2024-06-25 13:45:04]
User263711 - Posts: 30
Hi, i want to adjust my Daily Loss Limit but unable to do so.
Also I found 2 different ways to edit PnL settings -- which way should I use?
Edit Trade acccount or use the Menu Bar > Global Profit Loss Management (see attached)
Last issue I have on this - my position is down -$300
but the Global profit Loss management shows only -100C ... it appears they don't sync up. What could be the issue?
imageEditTradeAccount.png / V - Attached On 2024-06-25 13:44:54 UTC - Size: 63.44 KB - 168 views
imageGlobal PnL Management.png / V - Attached On 2024-06-25 13:44:57 UTC - Size: 44.36 KB - 191 views
[2024-06-25 13:48:47]
When I update / commit changes to the daily loss limit, it says Server error : Operation Not allowed (see attached)
imageNotallowed.png / V - Attached On 2024-06-25 13:48:43 UTC - Size: 127.9 KB - 191 views
[2024-06-29 04:51:25]
Closing this thread. Saw your video on Server side User P/L management tool
Will stop using Global PnL management. Instead will only use Server side User P/L management tool
