Date/Time: Sat, 26 Sep 2026 17:17:52 +0000
Sharing Denali Data between Virtual Machines, Possible?
View Count: 509
| [2024-06-25 12:56:38] |
| pjk0225 - Posts: 44 |
If anyone with experience could chime in, would sharing the host PC's IP address with a NAT network work for this? Wondering if this is possible so I can have two separate instances of SC each on their own VMs, connected to the same Denali data feed at once. |
| [2024-06-25 15:53:46] |
| John - SC Support - Posts: 48028 |
If you have 2 Virtual Machines running, then the Denali Exchange Data Feed will see that as two separate computers trying to get the Denali data at the same time. You can make this work by paying for a second set of exchange fees. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously If you are asking if there is a way to circumvent the Denali check for 2 systems, then we recommend not posting that on our Support Board. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
