Date/Time: Sun, 08 Sep 2024 00:37:46 +0000
RTH ETH
View Count: 151
[2024-06-25 10:11:09] |
User131975 - Posts: 57 |
Hello, is it possible to display the RTH session on the chart by default and then display the ETH session with one click? I want to use the whole thing on my TPO chart and on the normal candlestick chart in the futures. |
[2024-06-25 15:40:19] |
Ctrl-G by default is the keyboard shortcut for "Use Evening/Full Session". You will see this option under the "Chart" menu. You can adjust the keyboard shortcut to anything you want. Refer to the following: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-25 15:43:30] |
Thank you Can I also make a TPO chart for RTH and ETH separately? |
[2024-06-25 17:48:52] |
The TPO profile has an option for displaying the Evening Session separately. Refer to the following: Time Price Opportunity (TPO) Profile Charts: New Period at Day Session Start When Using Evening Session (1 Day Period Only) The option for "Chart >> Use Evening/Full Session" will also apply to a TPO chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-27 09:53:56] |
Thank you!
