Date/Time: Sun, 08 Sep 2024 00:02:57 +0000
Continue using study for a new study
View Count: 90
[2024-06-24 21:04:54] |
novaxt123 - Posts: 41 |
Hello I have a question about "Color Bar Based On Alert Condition". I have a study "Color Bar Based On Alert Condition" with a formula in my study collection. This study shows a signal in the chart. Now I would like to use this study for a new study "Color Bar Based On Alert Condition". So I would like to write a formula like: If all conditions from study 13 are met then show a signal. Is that possible? I don't know how to write a formula for that. Can it work like this: =AND(ID13.SG1 = THRUE , ..... ID13.SG1 is a point above a candle that is set with a formula. |
[2024-06-25 13:30:15] |
You can base a "Color Bar Based on Alert Condition" on another "Color Bar Based on Alert Condition" study. To do this, you would enter the following for the alert condition in the new Color Bar Based on Alert Condition study: =ID13.SG1 Where ID13 is the ID of the first Color Bar Based on Alert Condition. One important item is that the new Color Bar Based on Alert Condition needs to be lower in the list of "Studies to Graph", as the general order in which they are calculated is based on that lineup from top to bottom. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
