Date/Time: Sun, 08 Sep 2024 00:30:53 +0000
Sierra Chart Closing Down During Replay
View Count: 224
[2024-06-24 20:22:57] |
Rich_B - Posts: 31 |
Hi My charts keep closing down during replay mode. This is highly frustrating as it is preventing me from back testing. When the problem occurs, there is no freezing or error messages, the entire program simply closes. I have so far tried the following fixes without success ... 1. Run in safe mode ... no difference (this rules out an issue with custom studies) 2. Replace and upgrade RAM from 32Gb to 64Gb ... no difference (this rules out faulty RAM) 3. Reinstall Sierra Chart ... no difference (this rules out corrupt files) 4. Install on and run from two different SSDs ... no difference (this rules out faulty hard drives) Short of replacing my CPU (currently i7 12700K) which will be very expensive, I am not sure what to try next. Any suggestions on a solution much appreciated. Thank you EDIT: The crashing appears to be triggered by the Trading System Based on Alert Condition Study. When I replay my charts without this activating they run fine. Any idea how I can fix this? Thanks Date Time Of Last Edit: 2024-06-24 22:34:51
[2024-06-26 00:19:17] |
Sierra_Chart Engineering - Posts: 16292 |
What this indicates is a stack corruption. We are thinking about this. Based on everything we know and you have said we do not think it is a hardware problem. We know a problem like this will never be reproducible by us. We are thinking about how to troubleshoot it. Try updating to the latest prerelease and see if the problem occurs with that version. But that does not mean the problem is resolved. It just means that it is being avoided. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-26 07:15:41] |
Thank you, for your response. I will try the prerelease as suggested and report back. Also, the same crash occurred yesterday when not in replay mode, so it is not isolated to replays as I first thought. Do you think programming my system in ASCIL will help as opposed to using the Trading System Based on Alert Condition Study? I have some experience coding in Python but not C++. I'd be happy to learn ASCIL if it fixes the problem, but it'd be rather frustrating to go through that lengthy process only to find that the problem remains. Date Time Of Last Edit: 2024-06-26 07:18:30
[2024-06-26 11:31:47] |
We are looking into the crash issue. Another user is reporting it. So we should be able to figure this out.
[2024-06-26 14:19:42] |
Thank you. If you could update this thread when you believe the issue to be resolved, that would be much appreciated. |
[2024-06-26 14:47:32] |
Come back to us in a few days. But based upon what we are seeing, we are not very encouraged we can determine what the problem is. We are never ever able to reproduce issues like this. And we believe the issue is external to Sierra Chart. Why it occurs with trading we are not totally sure but have an idea related to the size of stack space and functions. We may have a workaround which at the very least can avoid the problem.
[2024-06-26 14:59:36] |
O.K. will do. Thank you for your efforts in trying to resolve this.
[2024-06-27 15:37:10] |
Issue resolved. More information: Stability Issue in Recent Sierra Chart Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-27 15:37:20
[2024-06-27 15:55:32] |
Thank you very much. Credit to the SC team for dealing with this so efficiently and professionally. |
