Date/Time: Fri, 18 Oct 2024 03:41:25 +0000
Not able to download the applications
View Count: 109
[2024-06-24 20:08:35] |
User294529 - Posts: 1 |
HI, I was trying to download to my Mac via parallels and cross over the Sierra chart application but I was not able to finish the downloading. I have new Mac computer with chip and I’m able to download the latest version of Windows. Could you please give me any advice how to download the application? Would like to use it for footprint. Thank you for any advice. With kind regards, KM |
[2024-06-24 20:39:00] |
John - SC Support - Posts: 35333 |
The only thing we can recommend if you are having a problem using our standard installer tool, is to use the "Zip Installer" instead. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
