Date/Time: Sun, 24 Nov 2024 04:47:19 +0000
2024-06-24 13:25:42.352 | DTC Client socket (2) | Connect event error. Windows error code
View Count: 149
[2024-06-24 13:32:23]
bobstone249 - Posts: 28
2024-06-24 13:25:42.352 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
Hi, I am receiving this error message in a log which keeps popping up, can you please help?
[2024-06-24 13:34:00]
Sierra_Chart Engineering - Posts: 17154
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
