Date/Time: Sun, 24 Nov 2024 04:27:41 +0000
cant access custom files properly on macbook using crossover
View Count: 149
[2024-06-24 11:50:38] |
User198958 - Posts: 5 |
very complicated and diffucult to understand but basically i am using sierrachart on mac through crossover. I have purchased a custom chart loadout. I can add a custom stury so i know the files i recieved are there, but when i open the app by right clicking, the right click goes off and after nothing happens for a few seconds, before sierrachart just closes itself and nothing happens after i restart, any ideas?
[2024-06-24 17:49:52] |
What are you right-clicking on? You can not start Sierra Chart by trying to open a Chartbook file from the file system. You need to start Sierra Chart and then open the chartbook. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
