Date/Time: Sun, 24 Nov 2024 05:00:40 +0000
Adjust Trigger Trailing Stop
View Count: 174
[2024-06-23 21:34:33] |
jrob - Posts: 22 |
Hello, Is it possible to adjust the Trigger Trailing Stop Offset automatically based off a Study Subgraph? |
[2024-06-24 17:22:51] |
There is not a way to do this with the built-in tools, as none of the tools are setup to not continue to adjust the Stop after the trigger. You could create a custom study to do this. Refer to the following: Automated Trading From an Advanced Custom Study: Modifying an Order List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
