Date/Time: Sun, 08 Sep 2024 00:28:51 +0000
Checking Network speed
View Count: 133
[2024-06-23 10:18:17] |
cherioJJ - Posts: 10 |
Hi, Is there a way to check network speed using sierrachart? |
[2024-06-23 19:35:44] |
Sierra_Chart Engineering - Posts: 16292 |
Network speed is not relevant to Sierra Chart. Do you mean, the bandwidth that it is using at any moment?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-23 19:35:56
