Date/Time: Fri, 25 Sep 2026 13:38:31 +0000
Improvement Requests
View Count: 1418
[2014-08-23 16:33:11]
Marek F - Posts: 254
Sierra Chart Engineering,
I have two requests:
1) Could you please to add a feature for sort the list of the charts in the CW by the Chart Number. Now, it seems the sorting is desultory. See ChartList below.
2) Could you please to add a feature simply and quickly to shift a consecution of the Chartbook Tabs.
Now, it's possible only by General Settings -> Files To Open On Startup, but it require to restart the Sierra Chart.
I use a few Chartbooks and i would like to quickly shift the Chartbook Tabs, according which the symbol has more probability for good trade.
Best regards
Marek
Date Time Of Last Edit: 2014-08-23 16:33:54
imageChartList.jpg / V - Attached On 2014-08-23 16:30:45 UTC - Size: 26.22 KB - 523 views
[2014-08-23 23:51:24]
1. We will add this option.
2. This is difficult and will be looked into later on.
Date Time Of Last Edit: 2014-08-23 23:51:35
[2014-08-24 07:58:53]
Thanks,
Marek
[2014-08-30 09:01:53]
Sierra Chart,
Have you already implemented feature 1?
Marek
[2014-08-30 20:32:39]
1. Not yet.
[2015-01-18 18:44:03]
User50629 - Posts: 10
To: Sierra Chart Support,
Could you add a feature or an option to change the sort the list of the charts in the CW by the Chart Number to its original alphabetical order.
Thank You,
Van
[2015-01-18 19:09:34]
You need to disable Global Settings >> General Settings >> General 2 >> Sort CW Menu by Chart Number.
