Date/Time: Sun, 24 Nov 2024 04:30:07 +0000
Funded Apex Tradovate
View Count: 291
[2024-06-23 00:32:31]
User302346 - Posts: 1
Hi, I have multiple apex tradovate (not rithmic) funded accounts. I am trying to use the copier trade function that sierra charts has. Is it possible to link my multiple funded accounts to sierra and trade from there? Ive heard many things but im not so sure about connecting the multiple accounts to sierra and copying the trades.
Thanks,
[2024-06-24 13:19:38]
Gradient - Posts: 89
From what I've seen this is possible. You'd need to connect the accounts then can click "Menu" on the DOM, highlight "Settings", then select "Order Allocation to Trade Accounts".
You then select the master account and add the others. The multiplier refers to what multiple of lots in the master you want to trade in the remaining accounts.
For example, a multiple of 1 equates to trading the same lot size across all accounts.
See attached screenshot.
imageSC Trade Copier.png / V - Attached On 2024-06-24 13:19:31 UTC - Size: 39.1 KB - 64 views
